Root Home Screenshots
Velocity 1.0 ADW Launcher Fancy Widget Dark Passion icons
Here are my screenshots. I use my phone 95% for business, so I wanted something clean and simple.
ADW Launcher set to 3 panels
Velocity .1
Icons are "simple" - I had to add some for my use (I found original set on the main Android Forum).
Wallpaper is Black Design from Zedge
Left panel: Music widget
Main panel: Calwidget (4x2)
Minnemalistic Text (battery stat)
Right panel: Minnemalistic Text (time/date)
Stock Weather widget
I fired up my ancient version of Photoshop (CS) and did some slight variations on the dark HTC wallpaper that seems to be fairly popular.
Think I've finally ended up with a look I'm happy with...lol. I'm using ADWLauncher EX as my launcher.
The Cowon type clock/date widget is something I found here:
[APP Widget]Cowon D3 Clock - xda-developers
Kind of a cool widget (IMO). Icons are metrostation icons by yankoa. Battery level is Circle Battery widget. Calendar is Smooth Calendar. Weather widget is SiMi Clock Weather.
This will be perfect when the jamt port for velocity is done =)
Main screen - Typoclock widget
Second Screen - Switch Pro widget
Third Screen - Beautiful widgets 4x1 weather ('Simple Grey' theme)
Dock Icons are the grey text from Classical Gas, they can be found here:
http://themedroid.com/2010/11/grey-text-icons/
Wallpaper is the Zedge design modified by kyle5434
Velocity (of course)
LauncherProPlus (of course)
NoClock for Velocity
Clockr for my main homescreen for display of time
Modded app drawer icon with LauncherProIcons
SwitchProWidget for all my power control needs
Velocity OC'd to 806 running 25 apps installed, most to SD w/ 82 MB remaining
I was thinking the same thing and I like how the Beautiful Live Weather sun looks integrated into the scene, just a major coincidence but nifty none the less!
Thanks! The newest version of beautiful widgets lets you use a custom wallpaper and still have the animated sun and moon. I took that pic in Lewes, DE. I have a place thats only like 4 miles from the beach, and with all this cold weather, that wallpaper almost cheers me up!
I purchased Beautiful Widgets just so I could have those power toggles, but I can't find those specific ones. Where did you get them?
Access beautiful widgets from the app drawer. Select Toggle Skins and download the ones called arialNarrow by Kjell Kernen
*if you weren't referring to the skin, you have to add each one as a widget. to do this just add them like normal widgets and they'll be under the beautiful toggle widget option.
my current setup but soon to change once i find some good icons and a way to change the green colors on the launcher/notification bar..
velocity 1.0 w/ no clock mod
A big help, Thanks!!
Velocity 1.0
Ares HD Icons
First Screen
Pandora Radio
Music Mod
Second Screen (Main)
ExtDateWidget
Shortcuts:
  • Stock Camera
  • Stock Gmail
  • Stock Market
  • Music Mod
Third Screen
Power Widget
SilentMode OnOff
CalWidget (4x3)
Dock
Phone
Facebook
App Drawer
Messager (GOSMS)
Browser
Lock Screen
Clockr Evolution
Battstatt
"Just Simple" Lockmod
how did you get that lock screen may i ask?
Mines boring because I can't get away from the HTC style clock and I can't get a grasp on how to use the minimalistic text widget properly.
