Root homeless kernel and number 2??
How do you know it doesn't work?
I've used it plenty of times before.
I have installed number 2 v1.8.1 and i install the homeless kernel.. but the phone is stuck in the bootanimation and then restarts and again stuck in the bootanimation .. well the phone does not start .. I had to re-flash the ROM
ijust flashed homeless 1.3 on #2. same thing. went to boot animation and restarted . went to boot animation again and then basially froze and shut off . just did a restore. idk maybe its our phones?. funny thing is i was trying to flash better battery nd ended up flashing homeless kernal LMAO.!
That combo did not work for me either so I went back to speed kernel
meaning u went thru a bootloop also ? or u were able to get to the lockscreen? . iwasnt able to get past the bootloop. i really want this kernal for battery. ive heard good things. tweaking #2 kernal did no good for me either.
Yes same thing that happen to you
