Root Honeycomb Bootable SD card?
Sager
Can I make a bootable SDcard with Honeycomb that will work without rooting my nook. Right now I have one that works with FROYO but I wanted to know if I could do the same to try out Honeycomb?
yes. it works the exact same way. burn the image to sd card, turn off nook, put in sd card, turn on nook. voila
Hi Sager,
Can you tell me what instructions you used to create your FROYO bootable SDcard, and if you are happy with its functionally ? I am looking to do that, but notice there are many different files & procedures.
Thanks,
- Briaom
Since Froyo is working so well, I'd flash that to your Nook and put Honey Comb on the sd card.
