Root HOT in my pocket!!!
polarbehr
Member
Well my dx keeps wanting to install gb, only problem is root, rom and removal of bloat. The update keeps failing to install. Its killing my battery and getting hot in my pocket. What do I need to freeze with ti in order to stop it from trying to install gb?
Freeze "updater". Or if you're really handy with yer phone you can go into root explorer system/app, scroll down to "blurupdater_VZW.apk" and rename it to .bak.
Well I wasn't able to freeze it because I don't have the full version of ti, and i was not able to change the name of blur_updater.apk. Using file expert I did however delete the actual gb update that had dl to my phone from verizon. No problems so far and that was last night at about 830.
Cougar throws a hot pocket down the hall and hits Steven in the back of da head as he runs away...GOT YA!!......:p
Why don't you just sbf back to .340 and install p3droid's .596 rooted and doedexed rom? Problem solved. BTW, Liberty .596 version is amazing.
