sdrawkcab25
Extreme Android User
This is a kind of long process of what I went through to kind of get my phone back up and running after a few small force closes snowballed. My phone is up and running now but still not at 100%, any input would be appreciated.
My phone's previous software information was the following.
Virtuous Rom 2.6 with King's BFS #5 kernel not overclocked and the Incredible Revolution Theme.
About a week ago I started noticing some random force closes with some of the HTC services (.com.htc.downloader, or something similar). It would force close but never caused me any problems that I would notice. The only new app I had added in about a month was "Angry Birds Lite"
Then yesterday my phone started acting sluggish all of a sudden so I decided a reboot was in order. I used "quick boot" and selected reboot and my phone started to reboot, and then started to boot loop (it would get all the way to the droid eye animation and sit for a minute then try to boot again). I pulled the battery and attempted to let it boot again and it was still stuck in the boot loop. I then booted into recovery and attempted to restore one of my backups with no luck, now it would just get stuck at the first white HTC incredible screen and sit for half an hour if I let it. Next I did a full data/dalvik cache wipe and tried to restore a couple different nandroids with no luck.
My next step was just to re-download Virtuous and start fresh. I was able to get Virtuous to boot but after going through the set up .com.htc.launcher would go into a force close loop with no way out of it, after another few attempts at loading Virtuous and other Sense based roms and having them all fail with the same .com.htc.launcher force close loop, I tried to go to a senseless Rom and was able to get Sky Raider to boot with no issues. But I wanted my phone back the way I had it.
My last resort was to unroot back to stock(S-off still). I downloaded the stock PB31IMG.zip and flashed it to my phone with complete success. Next I needed to root my phone again. I used the UnrEVOked 3.2 and got my phone rooted, but I couldn't boot into recovery. After much trial and error I was able to get recovery to load by flashing Adrynalyne's version of clockwork mod. I then flashed Virtuous 3.1 with the stock kernel onto my phone, and then I was able to flash back to the standard Clockwork mod recovery.
My phone is up and running now fine when it's on. But my issue now is that I can't do anything through rom manager or manually through clockwork mod to my phone without my phone getting stuck in a boot loop or getting stuck at the first HTC incredible screen after booting out of recovery. Even after just making a nandroid backup of my phone (without loading any apps) it will get stuck at the HTC screen. 95% of the time, clearing the dalvik cache will let my phone boot, but if I had loaded any apps they are all erased and just a placeholder is left on the home-screens. Sometimes I need to do a data wipe to get it to boot.
So..... Any suggestions anyone?
edit: I'm using a newly formatted FAT32 sd card since flashing back to stock and rooting again
