Root how can i get stock 2.2.2?
Hi, I recently got an Optimus M from a friend. He has a custom ROM 2.2.2 on it, I'd like to go back to the stock 2.2.2 ROM. Does anyone have it? I know there is a debloated version, but I'd like to be on the full stock ROM. Thanks to whom ever can help me.
UPDATE: I'm all fixed, I flashed "teamchhickeneater" rom and it gave me what i was looking for. most the roms on here seem to use ADW and I really didn't care for it. Now i got a more stock look and also go luancher xe on the phone. thanks to all you guys trying to help. :D
im not sure if doing a factory reset would take you back to 2.2.2. it might revert you to 2.2 or 2.2.1. You could see if the guy happened to make a nandbackup that might still be on the SD card prior to the custom ROM, most likely he did, but question is.. is it still on your SD card or available on his computer maybe? ive been told you can do a Nandrestore and revert to whatever ROM you were using, so long as you have custom recovery flashed. good luck.
I am actually running on stock 2.2.1 with the r.O.C.K anyrom kernel OC to 768 stable and it works great.
He is running a Stock-like custom ROM, you CANNOT and SHOULD NOT (sorry if it looks like I'm yelling, this is very important) ever factory restore a custom rom or even a rooted stock ROM, doing so sometimes cause people to brick. If you need to factory restore after rooting just do what the OP guy wants to do:
To the OP guy, you have to downgrade to 2.2.1 with LGNPST,
Here's the guide:
http://androidforums.com/optimus-m-...ide-downgrade-lg-optimus-m-2-2-2-2-2-1-a.html
After downgrading, all you have to do is upgrade with the LG update tool and your good :D
