BlueMuscles
Hmmmmmm I like the power on audio ...well just the part where they steal the 3 stooges act with the Helloo Helloo Hellooo.
Anyway I could just keep that part ?
Isn't this topic about helping each other... dude haha I'm studying Sociology and Spanish, I'm not that smart.Use a terminal emulator and do it manually. If you really are a college student I bet you could figure out the right commands to run with a few google searches
I forgot about the startup sound I promised you guys.
Here's a quick one I pulled and slightly modified from Zedge.
I might just decide to create a whole new set of system sounds...
I'll keep in touch about that one.
Just unzip the file (AF won't allow upload of .wav files), and you should be good to go!
What I did was rename the original file to "PowerOn01.wav" and named my replacement sound "PowerOn.wav" and then moved it in to the "etc" folder.
Make sure you're properly rooted. Get the "Root Explorer" app and use that to turn the etc folder to r/w and move the files.
There ya go.
Yeah once you do that it should work.ok, so what should i do if i have already deleted that file? Just name my wav file PowerOn.wav and place it into the 'etc' folder?
