Except as far as I can tell, there is no way to (ever) turn off backup assistant short of doing a factory reset >.<Just sync to google contacts and everything is saved there. No need to use that worthless memory hog Backup Assistant ever again. Mybackup pro is also grand.
My settings on my "backup assistant" are set to auto and they seem to be running OK for backing up my contacts and what not but is there a better way to backup my phone? A full restore method for my current setup and not the default/factory settings?
Thx
1) Use this: It's well worth the price, if you're rooted.
Titanium Backup PRO Key ? root - Android app on AppBrain
2) Sorry, I gotta move this to the all things roots section.
