I don't do it often, had to think.
hold the button in on the stylus. While doing so, hold it to the screen for a moment.
That will do it!
That will do it!
Press the power button and the home button at the same time until you hear the shutter sound.
That will do it!
Then you will have a 1/2 wheel menu, choose screen write and touch it.
After there will be a check mark and and X at the top.. Choose the check to save to your gallery..
Thanks!That didn't work so good until I pressed and held them at the same time. Holding one then pressing the other wasn't productive@Stoney62 hold power key and home key at same time and wait till it takes a screenshot.
ThanksYou can also turn on
Air gestures. Settings | Control | Air Gestures.
With that enabled you can take a screen shot with your hand (position thumb up) & slide from edge to edge across your screen.
This is what i use....so easy and cool. Good to see some people actually took the time to figure out the gems on this phone.
youtube it.....hard to explain. You have to touch the screen with the side of your hand and slide across. Hand must have contact with the phone, so not really an "air gesture".
Now that works- so I'm wondering how the call answer works? Oh, and one other thing-- now I have to delete all those screen shots I didn't save off Dropbox!
