Hi folks. :ciao:
You can follow this guide to get back to Gingerbread. Its pretty simple. Just read through carefully before you start.
Have fun.
Thank you so much, worked perfectly!
Great! Glad to hear it. Didn't take you long either.![]()
Well it looks like I'll have to do factory restore now...
Im getting a ton of "Sorry! The process xxx stopped working! Force close" errors.
Cant open contacts or messaging :\
Thats common. Do the wipe data/factory reset in recovery and the format cache partition.
Hello,
I read the posts on this issue and my question is in relation to my phone and its compatibility to the instructions above.
The model number is:GT-I9100
The baseband version is:I9100JHLPC
The Kernal versionis:3.0.15-1087786
The Build number is:IMM76D.JHLPC
Can I follow the instructions above?
Many thanks,
Ilan
Hello! I'm new to the forum. But I am stuck on Odin. I have downgraded my S2 to gingerbread 2.3.6 before & for some reason now it is not allowing me too. Odin just keeps on saying failed. I'm doing everything I did before also. Could anyone help me with this? Thanks!
No offense. But you really don't know what you're missing if you would just upgrade to 4.0.4 instead of taking a step backwards to 2.3.6.
Just my two cents.
2.3.6 is much much better than 4.0.4.
I think you had something else going on. I doubt many agree with you.
I have to agree, cm 10.1 blows GB away.
