drummer1422
I know, stupid question...But how do I get to CDMA Settings? Thanks
well...I think the setting you are referring to is switching the auto gsm setting to cdma only. That issue was fixed many many updates ago and the menu was locked with that same update.
check out that thread and there are a couple of really good battery related threads as well
