Help How do I manage files on the SD card
politzer
Spotify apparenlty isn't supported on the phone although it's been working on and off for me.
It's been suggested that I delete some Spotify data from the SD card, but I don't know how to navigate there to be able to manage the data.
VZW tells me that it's not possible without removing the SD Card and using a reader to do it.
Any advice?
Thanks
there are like a hundred apps that you can use if you want to look at the storage of your phone. ASTRO is a good one. If you are rooted, I would get Root Explorer if you want to get into the system of the phone.
ASTRO File Manager - LINK
Root Explorer - LINK
OK, I've downloaded Astro and found the file I want to delete, but can't find a delete function. Any help?
+1000 on the Root Explorer advice from above. Others work but its the best. If I had to pick my one quintessential paid app, it'd be that.
Root Explorer is a must have for any rooter who likes to tinker with their phone. Titanium Backup is another app also, if you flash ROMs a lot.
