Root how do i remove a2sd from phone
this is my issue i messing with my and i was in partition and it did something that it stoled like 3 gb from my memory card i went to terminal emulator and worte this code down a2sd remove and nothing has happen i reformat my memory card and nothing i put my partition back to normal and still nothing where is my 3gb of memory can it be in a invisible folder
still not working i just tried that and its still missing
Sorry you're having trouble removing the partition from your SDcard.The older builds of CM7 will not remove the partition,they just don't require a partition for the stock APPS2SD feature to work.I'm gonna GOOGLE for solutions for your partition problem.Just be aware that if there is any data on your card that formatting & partitioning will delete that data,so,back up your SDcard contents to an external source beforehand.
GOOGLE is your friend w/this partition deleting issue(or just about anything for that matter)!
Many,many different methods of deleting the SDcard partition,too many to list here.
i found the solution i had to put my phone back to stock 2.1 and it work perfectly it gave me back 3 gb back
Did you wipe/delete/format your card?
Just VERY curious,as there are more & more people opting for CM7(and the DT A2SD that comes w/it).Inevitably,there will be those such as you who may want to opt for a non DT A2SD ROM & will be interested in how you restored your SDcard to a non-partition status.
What he did was set the partition(s) sizes to big for what he wanted. To completely format the sdcard I took mine out and put in a card reader and formatted it via windows.
well what i did was put it back in stock and just went to format card on the stock settings and it just brought it back to normal... i tried what playful god said about putting it in windows and format it there but it didnt work for me ..
