htcwaldrop
My EVO was rooted when I bought it. I'd like to update it to the new Android that was recently released. How do I do this?
welcome to the forums!!!!!!!!!!!!!!!!!!!My EVO was rooted when I bought it. I'd like to update it to the new Android that was recently released. How do I do this?
Update:
For the most part, everything seems to be working now...except for a couple of problems.
1. I can't tether. When I try it says "unable to start tether". Any ideas?
1. The HTC Sense isn't working. For example, when I try to add the clock widget to the homepage is says "The application HTC Sense has stopped unexpectantly". Additionally, I'm trying to remove the people widget off my home screen, but when I try, the same error pops up. Any ideas on how to fix this?
i would go back to recovery and wipe dalvik cache and cache and see if that helps.
I would try and redownload the rom, wipe cache and dalvik-cache and reflash the rom. You may have gotten a bad download or a bad flash. It will not erase your settings and data but just rewrite the rom and replace any corrupt files you might have that are causing your issues.Hmm...tried that and it didn't work. I even tried doing everything that you mentioned in your first post again.
There's a SuperUser application that came installed on my rooted phone that keeps closing as well. I think it was part of the jailbreak. If so, that explains why the tethering isn't working.
Any other ideas? Thanks again for your help. I really appreciate it.
Tried and didn't work. I'm going to pretend I'm stupid (which may be the case) and let you know what I'm doing just in case I'm off.
I'm going to the link (theMikMik.com • View topic - Download Links) and selecting v.2.42--MultiUpload and DL it my sim card. (I also tried to dl it from "Dev" host, but it won't finish downloading.
Once it downloads, I hold power and volume button and then select recovery. I make a backup.
Then, I select "wipe cache partition". Then I select advanced and then "wipe dalvik cache"
Then I "install zip from sdcard"
Then I reboot.
Thanks. Again, thanks for your help and patience.
If I'm doing it correctly, can I just re jailbreak it?
