How do you draw on a picture?
menmyjeep
I would like to know how you draw on a picture like you see in Lebron's commercial. Does anyone know and what app that is being used?
If I remember correctly, open a pic in the gallery and using the menu button choose edit. It will direct you to the location to download the photo editor app from Samsung (required to register first and verify email). Once installed, it is easier to open a photo directly from the editor app to draw on it. You will also be able to draw on it within the S Note app.
@menmyjeep Everyone who replied is correct.
The commercial makes it look as though Lebron didn't have to do any of what was suggested here.
I prefer the Samsung's Photo Editor for all the options it provides.
If you use the Photo Editor app you'll also have 2 copies. Your original and the one you edited once you click save.
I use s note, go to s note, menu and import, then select image from gallery then it will shown up in ur s-note, opent it and you got it, do whatever you like with the picture
Like Donas, I use the S-Pen to take a screen shot (hold button and double tap on screen) and then annotate on it and save once I'm done. Found it's the quickest way :).
