artvandalay22222
MODEM RECOMMENDATION: Please flash JPY modem, enable WCDMA 850 (by typing *#2263# - COMBI BANDS - WCDMA 850 (FDD V) [*]. If the star is not there, tap on that line)and see how is battery life. For me is great. If you have battery drain, you might want to do this. If your connection drops, go to settings - wifi settings - mobile networks and set the type of network to the one has most coverage on your area.
I want to try the Continuum Rom again. On THIS page I read the above comment about flashing a Modem.
Is this done before I flash the Rom? Is it done After? Do I just put the modem on the sdcard and rename it to update.zip?
Thanks for any help
