manticore999
I have a GN2 from Verizon. It doesn't 'notify' me when the batter is charged?
Switch to AT&T. When my phone is fully charged I get no sound indication only a message on the screen.
Same for me.Same. I have AT&T too, so the sound must be a Verizon thing. It does light up the screen for like 5 seconds when it is fully charged though. I only noticed it when I was charging during the day and I saw the screen lit up.
The only comparable problem I have is the phone lighting up in the middle of the night when it is fully charged. I am on on AT&T.
My solution = flip it over, problem solved.
Although I'd be frustrated too if there was no way to turn it off!My solution
Delete the battery full.ogg file in system/media
I'm not sure (and I'm not on VZ) but what about the notification when you plug in the charger, that might be one.I haven't been able to test the system notification, because I don't get a lot of those notifications and can't figure out how to trigger one. However, hopefully, the battery notification is a system notification
I think that's charger specific. Presumably you're talking about the OEM charger. Of course it's *possible* that the actual charger is built into the phone & the 'charger' you plug into the wall is simply a converter, changing 110 AC into 5 DC (USB power). In that case this would work for any 'charger'.BTW, leaving the phone on the charger after it's full has zero effect on the battery. It has circuitry that stops charging after it hits 100%.
