Help How do you stop "system updates" from running?
Rarewolf
Android Expert
I have ctmod so idk why it keeps running. I don't need it.
XP
Its probably the main cause of my battery draoning. :(
There us a simple solution to the update nag... Download ' autostarts' from the market go into ' after startup' and find the 'google services framework' entries. (there are 4) find the one that says 'com.google.android.gfs.update.SystemUpdateService$Reciver' (third entry on mine) and disable. Reboot and never be bothered by it again.
yes AutorunManager is free and can do it. I just did it. You need Root access (we all do dont we ;)). hit advanced mode. once it loads you need to hit the menu button and check the options of Show system Entries and Enable System ap Disable. From there you can find this reboot setting and disable it. THANKS FOR FINDING THIS UPDATE FEATURE!!!! Ej06 is a good build.
