Rambler358
So I got the ProClip mount for my Evo. I'm curious how the phone knows it's in a holder?
Thanks! I thought magnets would hurt reception or other phone functions somehow, interesting...With a magnet in the dock, that kicks it over to car/dock mode.
The ProClip holder for EVO I got doesn't have any pins on it:from reading around in the accessory sub forum..there are pins in the usb...pins on the dock , the phone recognizes an extra ground in the dock tells the phone that it has been docked.
EDIT: And the phone's dock mode will activate without even a charger plugged in.
is it really magnets?
I've had the ProClip "mount" for almost a couple weeks now and like it a lot. Not exactly inexpensive, but a quality product with a "swede-like" covering that won't scratch the phone. It also holds the phone firmly in place, allows you to swivel the orientation, and has room for the phone with larger batteries and back covers.i love the proclip look btw...let me know what your overall impressions are
Do you have it setup not to?I have the Pro Clip mount and my phone doesn't go into "dock".
Auto-Launch is checked.Do you have it setup not to?
It does with mine. I do have Auto-Launch checked in the Dock settings though.HI, I purchased the same dock from ProClip, except mine slides into a power usb at the base. However it doesn't go into "docked" mode, even though I have that setup in settings. Are you saying that just sliding your phone into that felt covered holder with no power, puts your evo into "dock" mode?
