SilverDroid
Ok, first of all just to clarify, this thread is not meant to cause debates on battery life, how much your using your phone (or not), percentages of battery used by OS bug...., blah blah blah.
How much battery life do you reckon I've got left after 5hrs 15mins? (at time of writing...)
(Phone has not been used as I have been working, wifi is always connected, running 2.3.4 which has stronger wifi signal, though maybe uses a tad more battery.)
Only difference atm compared to any other day of usage (during work), is the fact that email sync is not switched on as I wanted to test with it off, to see the difference in battery drain.
So what do we reckon...? Guess your percentage...
P.S. This is a one time test. I'm not interested in how long I can make the battery last, or how little it does during normal usage. I am doing this just to see how much of a difference email sync causes in terms of drain as I believe it to cause more of a drain than wifi (which it surely shouldnt do)
