Help How Much Memory
jester68
Hi,
I have a galaxy Tab 3 7" can anyone tell me the correct memory card size I can put in it. I'd like to put a 64gb card in, I'm going on holiday and I'd like to put music and movies on one device, but I've seen a couple of things that make me think it will only take 32gb. Any help would be appreciated
I'm pretty sure that the Tab 3 only supports microSD cards up to 32GB capacity, but I'll move this to the device-specific sub-forum so that other uses can confirm/correct.
I wouldnt go beond 32g eith. Even if it does support 64g i doubt it will be stable. Using that much memory on a divice that only has 8g internal usually doesnt work out well. But try it. Let me know how it interacts with the os
