no, im on checkrom v4 with an ics themeooo niiice. is that the beta 2 ur running?
im guessing ics is the only thing u have running? no crazy wallpapers or widgets that suck up juice?
Real-life usage, after 101hrs uptime.
when it's idle at night, you want it as low as possible to minimise battery drain.
oh wow i thought i was the only one with tons of stuff running on my memory, i guess not!
The amount of RAM used has no bearing on battery consumption. Android keeps inactive apps/processes in RAM if possible, but if these aren't consuming processor cycles i.e. working then they use negligible power. Using a Twitter client as an example, it will occupy RAM but if it only polls for updates every 4hrs then it will only become active briefly at that interval and then use the battery. If it happens overnight and the screen remains off the drain will be miniscule.
Ok, so the clear memory is really only useful if you're nearing full capacity and need to free up some more...
I use my SGS2 for everything and it's still only around 350!
There's a lot of ram consumption on my sgs2 recently. Not sure why is that but here- have a look... http://i.imgur.com/YqwoNaZ.jpg
