Root [HOW TO] 10% battery in themed framework apks
The multicolor battery theme here worked for me.
O/W give me a day or two. I'm about to post a blue 10% battery theme.
You applied the mod made for Apex 1.0 over Fission 2.1 final and it worked? I was able to use yadawpaah's guide to get Apex 1.0 working when I was using it.....following the same procedure, I just can't get it to work on either Fission 2.1 final or rubiX 1.6.
If you figure out how to get the kangerade 10% mod to work on fission 2.1 final, let me know, it's driving me nuts.....:p
Well I finally got it working.
I took elements from kangerade and apex and combined them. Now I am getting the 10% readings I want and some blue elements from kangerade.
I kept most blue task bar icons from kangerade.
You can see the battery is reading in 10% increments:
The settings icons taken from Apex:
I didn't like the blue fill on the bottom notifications tab, so I used Apex's:
Now off to remove the task bar clock and I think I may be done (for now....lol).
