No. No, it really doesn't.I use Memory Booster Full 6.0.0 and it works very well.
How does it work?I use Memory Booster Full 6.0.0 and it works very well.
Ram manager. select the hard gaming option to keep more free memory at all times. this works by actually changing how much forgeround and background processes/services/and apps the system tries to maintain. I use cool tool pro to monitor ram, and you can tell the numbers change depending on which mode you select. Also, I use an app called memory locker to lock some apps (like the launcher) from being kicked out of memory.
Translation -If only I understood all that gobbledygook lol
My problem (as an alcohol dependant) is that I can spend all day learning something cool, next day it's a blur![]()
So I come on here and ask you guys probably the same question multiple times (and you kindly reply)
I love AF like really love it <3
Translation -
Try Ram Manager, you might like it, and you're not screwed if you don't.
Here's an honest residue cleaner -I just installed it. Root required. I just uninstalled it.
I have been using File Manager HD and Clean Master. There is a lot of really troublesome looking stuff in Clean Master. The ONLY thing I used it for was to delete junk (residue form uninstalled apps).
It is now uninstalled.
... Thom
If you want to control those parameters more closely and are rooted, Rom Toolbox and 3C Toolbox offer fun alternatives. (But also sneak in some snake oil so caution is indicated.)
I did not know that, thanks!You may already know this, or I may just not be understanding your post completely, but I wanted to note that there is also a custom setting for the OOM values in Ram Manager, so you can control the parameters more closely as you say. The custom setting is on the first screen below the default option, but you may need to scroll down to see it.
