Actually it isn't the one plan... as that hasn't been available to new customers for some time?
do you have a link to anywhere that its says all unlimited data contracts are going to be cancelled by three?
and see what happens. (That will be your first step to using unlimited data without ever topping up) - Tested on a sim which was 6 months old.iD mobile uses the Three UK network as a MVNO.
Here's a tip... Request a sim from them and force it to use Orange's APNand see what happens. (That will be your first step to using unlimited data without ever topping up)
Cool I hadn't heard of that company cheers mate.It's worth noting to you as the abolishment of The One Plan if you want one closest to it....
http://www.idmobile.co.uk/shop/plans/sim-only
- 2000 minutes
- 5000 texts
- Unlimited data
I'm yet to test it if it actually works with tethering due to one of newest 'Unlimited' tariff from a new operator haven't investigated the tethering detection methods used but I would assume it would be almost the same as Three.
Also GlobalGig....
Here's a tip... Request a sim from them and force it to use Orange's APNand see what happens. (That will be your first step to using unlimited data without ever topping up) - Tested on a sim which was 6 months old.
They specifically prohibit tethering in the T&C of all plans, so it's definitely a case of 'proceed at your own risk'.
That, otoh, sounds like theft. GlobalGig are partnered with Three, so routing traffic via another network that you've neither paid for nor have permission to access is very probably illegal.
Seems like (unless you use your hack) though it's 20qid for unlimited data (though you do get a lot more minutes) whereas it's still 15 for unlimited data on three? (with free tethering to another mobile device)
Right I wasn't sure if we were "allowed" but I have for a couple of years(although I recently dropped a pint glass on my tablet completely destroying it lol so I'm no longer doing that)
Man I really hope they don't drop the unlimited for 15 add on coz I'm using around 50gb a month (I know, selfish...).
Don't know where I'll go to if they drop that.. Maybe back to giffgaff?
Lol mate
Aye I remember when I was with gg a few years ago they would cut you off until you appealed (and waited days for them to reconnect you) when you got like 15~20 GB data use.
I'd actually forgot bout that man
"the network run by you " aye right!
(although i used to basically get my service for more than free by just posting in their help forums and getting payback points)
How easy is it to transfer your phone number every 3months mate?
And what does "excessive" mean?
I'm on 5.0.2 and still happily tethering mate (on OnePlus One)Please be advised that if you upgrade to Lollipop 5.1, you will lose tethering altogether!!!! (it's happened to me...my handset is a Moto G 4 G.)
If you apply the tethering_dun_required 0 fix, this will not work on 5.1.
If you do not want to lose tethering, do not upgrade to 5.1.
Some people are saying that Lollipop 5.0, allows you to tether. (I can't say for sure, as I haven't tried this)
I made a mistake by updating to 5.1, assuming that all will work OK, if only I can downgrade to kitkat!?
psionandy....how have you got your tethering to work ? (did it just work out of the box, or did you root then make changes ??)
SweetI just turned on the built in mobile hotspot... sorry
I managed to root the handset, and then made some changes as suggested, rebooted the phone and enabled mobile hotspot. (Bang...Sweet...Now tethering with Three and also ID Network....My netbook/apple devices/other tablets are working!!! (happy days!!!)
