Root How to change battery icon on esteem
So romtoolbox I did the battery icon didn't change what to do thanks in advance
Sent from my LDK-ICK v1.3 using Tapatalk
u can use ROM tool box or metamorph to changed any icon u want u can not use ROM manager to changed any icons
SMH..............Tool box not manager.
(Note to self. Don't make posts on AF before you have eaten.)
And yes I've never got TOOLBOX to ever change my battery Icon.
Which is why I use UOT kitchen to change JUST the battery Icon.
OK metamorph where do I get the zip for it
Im currently making a battery Icon for someone else on here through UOT. If you can get me your framework.res.apk and systemui.apk files I can make you one too. Or if you tell me what ROM you are using.
smh.... o_0
ive been trying to change my battery icon, just stumbled across this, been using romtoolbox, itll change everything else..... weird
Hi guys, try using "Always Battery" from the market. This app can show the battery icon all the time. It's not change your default icon but you can place it over the default icon. It's very customizable and no root required :)
Why does rom toolbox let me change everything but the battery icon, there must be an easy fix / reason for this. a permission a file r/w , what is it. Just want to change the battery icon
always battery.... no thanks, i want one battery icon running, not 2, and a custom one. now gears of war sign :)
i was wondering this too, because even with my ascend it wouldn't change it, well all the way with the ascend, it would show up beginning of boot, then back to stock. its longer and takes patience but the uot works great
I too have been trying to change the battery icon in my esteem with no success. Has anyone had success doing this with Rom toolbox? I did it once with Metamorph but then next time I tried phone froze and had to reinstall rom. I am using Broken Out Esteem 1.1 w/ Blitzkrieg Kernel.
