Thinking I can use it to connect a USB jump drive and also a 3G dongle for use of my tab 2 outside where NO WIFI is available, I purchased
http://www.amazon.com/ReVIVE-Series-DualFLUX-Charger-Samsung/ dp/B005XPXHCU/ ref=sr_1_5?s=electronics&ie=UTF8&qid=1337478093&sr=1-5.
When I use this charger which works OK to power my Tab 2, and use the second USB port on the charger to connect the jump drive, the jump drive is not recognised by the TAB. What am I doing wrong - is the ReVIVE dualFLUX charger not meant to be used thus?
Also how does one use the TAB outside, where no wIFI is available - Samsung says any Plug & Play 3G adopters should work. Will appreciate your suggestions. Thanks.
