J jaliy Android Expert Sep 4, 2012 #1 It used to be holding down the address bar but it no longer works
R Russell Ng Android Expert Sep 5, 2012 #3 I hardly use the stock browser but the first thing I would try is to clear the data and cache for the stock browser first. Factory reset is overkill.
Slug Check six! VIP Member Sep 13, 2012 #5 jaliy said: When i hold it down it becomes search Click to expand... Try tapping the URL first to highlight it, then long-press to get the cut/copy options.
