Root How To Create Droid Custom Boot Animation
nuttmeg
Extreme Android User
Instructions For Making Your Own Boot Animation
1. Download the stock boot animation to your PC: bootanimation.zip
2. Extract bootanimation.zip to a folder.
3. You should find 2 folders and 1 file: part0, part1, and desc.txt.
The part0 folder contains .png files which boot but do not loop. The part1 folder contains your .png files which will loop over and over again. The desc.txt are the settings you can tweak including how big you want your custom boot animation to display. 320x480 30p 1 0 part0p 0 10 part1 (320x480 = the dimensions)
4. This is where you get creative. In Photoshop or your other favorite image editing program, put together your series of .png files which will replace the images in part0 and part1.
Make sure your file names follow a series similar to this: boot_00001.png, boot_00002.png, etc.
5. Once you have finished being creative, replace the .png files in part0 and part1 with your new series.
6. Highlight part0, part1, and desc.txt and then right click and choose “Add to archive…”
7. Click the dot for “ZIP” and under compression method choose “Store.”
8. Make sure the .zip which is created is named “bootanimation.zip”.
9. You have now created your custom boot animation!
10. To add this to your Droid
Instructions For Installing Boot Animations
1. You have to be rooted in order to do this.
2. Download Root Explorer from the market.
3. If you downloaded via PC, mount your Droid and drop the .zip file onto your SD card.
4. Unmount your Droid.
5. Open Root Explorer, tap on “sdcard” and locate bootanimation.zip.
6. Long press on bootanimation.zip and choose “Move”.
7. Hit the back button once and locate the “system” folder.
8. Tap and open “system” and then “media”.
9. Hit “Paste” which should be an option at the bottom of your screen.
10. If there is already a bootanimation.zip file, let Root Explorer overwrite it.
11. Back out of Root Explorer, reboot your phone, and BAM!
12. Enjoy your new Droid boot animation.
thanks so much! i was always looking for this thread in other phones but they didnt have it so thank you so much!
your welcome, i thought it would be neat to have anyone who is willing to show some creative work for the ascend so all can have some unique boot animations and sounds...:D
just convert any sound to mp3 format and name it to android_audio and put it in /data/local
I can't get this to work, all I hear is PG's movie projector sound. I have a minute long MP3 named android_audio in /data/local.
