L
LgOptimusM
Guest
Help.
Help.
were you able to get the reset done?
Some time ago I rooted my phone and deleted a bunch of metropcs related stuff. Since I was using the opera browser, like an idiot I deleted the default browser. As a result of that I had the android market/google play problem. I couldn't download anything because of that stupid error.
I tried doing what you described above and I partially succeeded After choosing the language and what not I finished that set up and then I get "the application setup wizard has stopped unexpectedly"
When I close that I get a screen that's completely black with top bar. None of the buttons are working, besides ringer volume up/down. And I can receive calls. That's about it. Any ideas on how to fix this?
whoops lol.. id look around for a stock unrooted rom for your device and flash everything back to out of the box. you can always re-root and such later.
Im gonna go out on a limb here: im assuming you do not have a backup - is that correct?
here's a link to a guide that can help return to stock How to Return LG Optimus M to Stock - LG Cell Phones Blog . A warning first though: research first and follow the guide EXACTLY. This method (like other methods of flashing) can brick your device if done incorrectly so make sure your on point. Let me know if u need any help
I downloaded everything and installed LGNPST v1.2 ..when I connect my phone it says unknown device and where this pic is showing COM15, I have COM4. The part where you add the bin is greyed out. Help plz?
It doesn't matter what the pic says....
well I"m not able to load either of the two files
is the usb registering the phone at all? if you have adb and stuff installed you can check with the "adb devices" command. if thats not working, go into device manager (for windows) and uninstall the drivers attached to the device. download and install the correct drivers ---> LG Optimus M USB Driver - LG Cell Phones Blog
make sure that adb can read the device, then try and write the two files again.
