Ok, so
go to
HOW TO: Root, Radio & Eng S-OFF a Desire HD/Inspire 4G in 9 Easy Steps
and download the 1.32 RUU.
Run the RUU without your phone connected, and once it starts up on the first screen, go to your temp folder
(Right click on My computer > Properties > Advanced System Settings > Environment Variables to see where they are on your PC)
Once in your temp folder there should be 2 folders with long numbered names within { }, in one of them there will be a few files and a subfolder, inside that subfolder will be a wackload of files and rom.zip
move that rom.zip to your desktop and rename it to PD98IMG.zip
Make your gold card
Method Here:
How To Make Gold Card for HTC Desire HD
Now move the PD98IMG.zip to your goldcard.
Unplug your device, and plug it back in. Choose "Charge Only"
Make sure development is ticked on under Settings > Applications
download
http://www.driphter.com/downloads/JSL/Droid/fre3vocmd.zip
(ie9 users will see it as unsafe, override and download the 'unsafe' file, its perfectly safe, ie9 says its unsafe becase of the .zip file extention. FU Microsoft!)
Extract it to your desktop.
Inside you'll find three batch commands.... Fre3vo Part I (A9191), Fre3vo Part I (A9192), and Fre3vo Part II (along with the actual files needed)
Rightclick on the first (if you're a Telus DHD, or AT&T Inspire 4G use A9192, otherwise use A9191) and run as administrator.
it'll do its thing and find the exploit.
once this is completed, unplug your device and then plug it back in, selecting charge only again (it says this in the batch)
now run part II
It will complete and reboot your device into bootloader where it will proceed in installing the 1.32 image.
now you can go back to my thread at the top and root, radio s-off and eng s-off.
