How to dramatically improve your camera (picture and video) quality
uhm.. sorry for the late response... uhm the iphone cover needs, because the dust can't enter with this piece of "glass" because is pinched into the phone...
I belive bood solution for stopping the dust from getting into the phone when removing the plastic protectine screen from the back cover would be to stick (with double sided tape) a foam ring inside back cover. It would fit the gap between cover and squre glass piece that protects lens. Does anyone know, how much of the gap is there. I'd recon 1 mm ticker foam ring would do the trick.
Actually, I think the glue from the edge of the tape would probably attract more dust and hold it there right in front of the lens.
I gave it a try, and the ring stays quite firmly in place without glue, as the back cover pushes it against the lens cover.
You could also cut the inner hole of double sided tape slightly bigger to eliminate this issue. As the foam now acts as lens hood, it's probably best to use black foam, or treat it with black marker. I don't know, how much effect does it have, so any of you photo-experts please comment on this one.
On my wife's HTC, I removed the HTC plastic cover, and bought a Nokia N97 sliding lens cover and glued it with careful positioning to the back of the camera. Its flash window lines up quite well, with care. On my own Desire, as I have a fixed leather case, I designed my own retractable lens protecter (and again removed the HTC plastic lens cover).
I am sure somewhere on this forum, it refers to replacement hardened optical glass lens covers available for the Desire for about
I've just tried the cover on/off comparison with my almost new Desire (from Ebay, but it looks like the previous owner hardly used it). It's a subtle difference, but a difference all the same (caused by the fact that even brand new perspex will do something to the refraction). Colours are bolder without the cover, and there's an overall increase in sharpness. With the cover on, it's as if there's a thin mist overlaid on the photo.
It's a large file, but the differences are visible here (cover on-off, from left to right)...
http://www.sfocata.co.uk/misc2/desire_camera.jpg
(And that's after a 33% size reduction and 90% jpeg compression... the differences between the 1.1MB originals, viewed in Lightroom, are even more noticeable)
Any more news from the person looking into a bulk deal on glass replacements? Or are these watchglass suppliers our only hope?
Yes the most obvious thing in your picture is that blacks look blacker with the cover off, they have a grey cloudyness with the cover on. But the same affect is noticable on all colours if you look. Must be the light transmission through the perspex that affects the picture quality, and clearly it happens even with an unscratched cover.
I removed my cover about 8 months ago, didn't bother replacing it, totally unnecessary.
The lens is well protected, not that it's a great lens anyway.
Dust hasn't been a factor.
I wouldn't worry about trying to put something else in front of it.
how can i move all my games and appliactions from my internal memry to sd card? pls help me.. coz am running out of internal memry whenever i want to download some of my favorite games..:(
