Root How to enable adb in CWM recovery mode?
eruisi
Once I am in CWM recovery mode, I cannot see the device in adb.
In normal Android mode, I can see the device.
I am using CTMode+CWM.
Why don't you just use the update tool to 'downgrade' like you probably did to root, just this time don't run the exploit or flash cwm
Or that...
That idea sounds much less complicated :)
Edit- just a thought, if his sdcard slot is broken, how would he go about flashing the stock rom? I know the aio is a .bat, but where would he place the stock.zip?
Or that...
i missed that post. ;)
sure its just not the card? its the actual slot?
i suggest just wait or also aswe playgod for help maybe he can helpyou making CWM with enabled adb on recovery!
