Root how to fix gogle play error
its somewhere on the thread where the update is posted, just look for posts by me, i made a patch that night that will make those problems go away
on stock, cm10, or what other rom??? The play store doesnt play well with density changes. So if your density in the build.prop is set to something other than stock... set it back. ;)
stock update, and no it was something to do with the carrier settings, they changed carrier to chameleon kuz theyre idiots, and other things to sprint, i just changed it back to boost as well as got rid of a few of the more troublesome boost/sprint applications
