Help How to fix this android error
Hi I've been looking all over Google about this error and how to fix it. And I have found nothing. The error is called E: check version failed! I'm new to modding android. And I hope somebody knows how to fix the problem on my android. I'm trying to flash a new clockworkmod recovery. Thanks to all that help. :)​
You don't say what tool you are using to flash it. If we knew that we might be able to narrow things down a bit.
But to me that sounds like a checksum or signature fail. So are you sure you have a good download? Alternatively if you are using a tool which would check a signature you may need to turn that off.
I'm tried to install a update.zip of clockworkmod recovery through stock recovery. And this error E:check version failed! keeps showing up even with signed zips I sign with sign-em.
It goes like this
finding update package...
Opening update package...
Installation aborted
But it is quite possible that the stock recovery will only install official signed zips. That's certainly the case with the stock HTC recovery, I have no experience of ZTE myself.
That's one of the things people use a custom recovery for: to be able to install unofficial updates. So I'd suggest trying to find a custom recovery for that phone (and I do mean for the ZTE Midnight, not just any ZTE or any phone - you really do not want to use a custom recovery that was built for a different phone, as very bad things will happen).
