Root How to flash your A75
Am getting few PMs on how to flash A75. Thought I would post it as a separate thread to avoid confusion.
Flash files - Www.sendspace.com/file/19ma4k
Here is the link for the s/w ( a previous version of wat we downloaded.)
SP_Flash_Tool_exe_v2.1121.01.rar
Please follow this method to flash.
Install the drivers given in the forum. (The MT65x3 folder - Install driver file). Then restart the system.
Driver file: You can download drivers from here:
http://www.4shared.com/rar/lpydm4i1/mt65x3-usb-vcom-drivers.html or
http://www.4shared.com/archive/iI25ERFN/MT65x3_USB_VCOM_drivers.html
Run SP flash tool. Choose the scatter file (MT6573_Android_scatter.txt) and Downloading agent (MTK_AllInOne_DA.bin).
Untick PRELOADER.
Then run Download. ( if file not found error comes, choose each file individally DSP_BL, UBOOT etc..)
When the s/w scans for the phone, plug in the phone(switched off).
Flashing complete.
Revert in case of doubts.
hey rahul i want to flash my phone to default version of a75 which company preinstalled on my phone........have you any backup for that version...........bcoz update giving me some bugs
@Abhishek, I got a copy of it from the service center. @Raju, As far as I know the first read is always slow. But after that its quite fast. Have you tried the update?
As far as rooting is concerned; I dont think is rooting is risky if done roperly with guidance (ofcourse the bricking potential is always present :) ). And we are yet to find a way to root A75.
@vkrajuu
yup just consider buying a better memory card ! if you want ultimate speed go for Class 10 Micro sd cards and one more thing , do not ask your local ppl selling sd cards abt the Class thing they are always clueless abt what is class in sd cards . i ordered my card from Flipkart got immediate delivery (just 2 days and if you want payment on delivery) it is not very costly anyways ...
more over that is the only primary way also 100% guarenteed way for increasing the SD speed , after you fill up amazing amt. of data in sd card ( i think you have Class 2 sd card ) it does tend to get slow ...
more over, rooting is not as risky as you have fear in your head, droid being a old platform now almost every result of actions are well anticipated.
more over if exploits are found there is no worry abt rooting, the best part, even if root it just software hack and almost nothing to do with hardware ! hence no prob abt mmx hardware also being from mmx those ppl in there service centers are illiterate abt rooting thingy ! hence you can just ask them for a replacement if you brick your device in warranty .. and anyways A75 is not rooted( at-least now).
@Rahul.. Thanks mate. FYI I have a Transcend microSDHC Class 4 memory card. With the above wise words, I will wait for the day, till we find a way to root A75.
Please if someone has rooted the Micromax A75 please inform with the procedure and necessary recovery files...
Please i want to root my phone....
Thanks in advance.....
Consider making this Thread straight forward ...
Its annoying to have 2 links for the same stuff ..
+ there is no need for sp-flash tool ( only ) now. ..
it is better with the new package stuff ...
Pl help me in installing procedures for uB a75 v2 in my mmx a75..
Waiting for ur valuable replies..
i downloaded ub a75 2 v3. i have flash tool & ub a75 2 v3..
i need to know wat is the procedure to upgrade/upload to my mmx a75..
pl help me on this issue..
i m flashing my a75 but it not working l...
pl correct me if am wrong.
i switched off my mobile, and flashed it using SP flash tool.every time it told download ok.
but after switching on phone is reset, nothing is change only my new installed apps deleted. ...i flashing (with micromax A75 new version) my mobile so many time as per karthik video on youtube . but nothing is work, i dont any idea my phone flashed or not, everything is same.
Pls help me out. i used still micromax A75 New Version, Root4, Root5 but everything is download ok but nothing work in my mobile.:confused:
Well ,
Just see the app drawer .. if it has a superuser app then its fine ;)
also In the settings > about phone
You will see UB-A75-1@Ninad_Root ! if using UB-1 ROM
or A75@Ninad_Root if using Root5 or above ;)
Cheers :)
Well ,
Cheers :)
thanks ninad
but superuser apps not add in app drawer.
i check about phone and see this.
Basebend version
MAUI.11AMD.W11.37.SP.V2.F1.P1,2011/11/22 23:33
Kernel Version
2.6.35.7
Build Number
[SW Version] A75_0201_V3006
[HW Version] A75_mainboard_P2
Pls Help :(
thanks ninad
Basebend version
Kernel Version
2.6.35.7
Build Number
Pls Help :(
Now try one thing :
Flash UB-1 again ...
then see back !! for Superuser.apk and then input "su" in terminal ...
See if u get a prompt :p
thanks ninad
Basebend version
Kernel Version
2.6.35.7
Build Number
Pls Help :(
Choudhary ji pls check im flashing one more time if wrong pls correct me
Installed drive
run flashing tool
Untick preloder
mobile switch off
press F9 (download) button
searching device
after searching downloading start
download OK :)
unplug mobile
switch on it take some time to start
ok it start :eek:
nothing is done, every thing is same but phone reset only.
what to do chaudhary ji pls help me
OK i try one more time pls stay with me
Yes it's works, u Rock k k :) :D
i found superuser app but after execute open android market loading loading loading. infect its eating my 6 battery point.
how to use superuser apps and there is no file manager but fine i will download from market,
now i m update superuser app. what is next
