Root How to get Gapps?
Dabrador
Just installed the latest CM and for the life of me I can't find out how to install the gapps.
Can someone help me?
Next question...
How do I use ROM Manager to install this? I'm not used to this app. I usually go into cwm through D2 bootstrap.
I've got the zip on my SD card but can't figure out how to install with ROM Manager.
Thanks!
Next question...
Thanks!
Just push and hold the power button; when you get the menu pop up, select "Reboot" and then select "Recovery". From there you will go in to CWR and you can flash Gapps.
Well...I just tried this and the phone stays at the screen that says Google. Nothing then happens.
Any thoughts?
Any thoughts?
It's happened to me on occasion that it hangs like that. I suggest pulling the battery and then trying again, it always works for me when that happens.
I've tried that a couple times now and it hangs every time. If I open ROM Manager and select 'Reboot into Recovery', the same thing happens...it hangs on that screen.
What do you think?
What do you think?
That's a bit strange. Try this (not sure if it will fix your problem, but it might):
1. With Root Explorer or ES File Explorer go into /preinstall/app
2. Delete the NFS Shift game file and then try again.
Don't have NFS Shift game. This is strange...I just can't get into Recovery whether through ROM Manager or Reboot option.
I read somewhere that you MUST NOT install the D2 Bootstrap app while on CM7 so I can't even use that.
I really don't want to go through another SBF. Any other ideas?
The NFS Shift file will still be there even though you don't have the game installed.
If the above doesn't work it looks like you may have to re-install the Rom and hopefully that will fix it, if not sbf time.
Oh...ok. I don't have Root Explorer yet because I don't have the Market app yet installed so that I can get Root Explorer.
How can I get into that file to delete it?
Was able to install ES File Explorer. Went into the /preinstall/ folder and it says that it's empty.
Now what? I'm open to reinstalling the CM7 ROM, but how since I can't get into recovery?
I think the easiest thing for you to do is to just sbf and start again.
I just realized it's been awhile since I did an SBF. The method I used was a linux disc that took me all the way back to Froyo.
What's the easiest SBF method to get me back to CM7?
If you don't have all the drivers and RSD Lite already setup, then the cd might be the easiest.
Although there is a linux cd that will take you to .602 without having to go to Froyo and you can root .602 with a one-click through a PC.
Look at the very first sticky in this forum by SimsDelt.
http://androidforums.com/droid-x-al...ad-602-sbf-root-process-updated-9-9-11-a.html
Here's what I've done so far...
I went ahead and did an SBF back to stock Froyo 340. After that, I rooted using Z4 root, then installed D2 Bootstrap. After that, I attempted to get to GB 602 by using TBH's AIO 602 through their app.
The AIO zip said it installed fine so I went to reboot the phone and it stayed at the red Motorola logo screen and did nothing. I removed the battery, reinstalled and it went back into recovery. I attempted to reboot again and same thing...it stayed at the red Motorola logo screen.
So I did an SBF back to stock Froyo 340 and that's where I am. No root, no nothing until I hear from the experts.
I want to end up with CM7 for GB kernel.
My current baseband is BP_C_01.09.13P and the Kernel is 2.6.32.9-g55626e1 w30471@il93lnxdroid08 #1
My thought process was I could root Froyo, install TBH AIO 602 and then install CM7 for GB Kernel on top of that, but it's not working.
So, how do I do it? The phone is on the charger, so I'll have to re-try tomorrow.
Thanks in advance everyone!
Anyone? I'm not sure if my radio and kernel are preventing me from doing this. Any advice would be appreciated.
Just follow the link I gave you in post #20 and you don't have to worry about being on Froyo and then using the AIO.
Side note:
You sure you have a good download of the AIO??? It maybe corrupt.
