Hi
I just received my tablet today. Reviews on it said it was easy to get started. Should of been my first clue. I bought a Cobalt Tab S800 8 inch; Android 4.0 It came on, I plugged it in to my computer and immediately there was a problem. I didn't have a drive for it. Looked online and the only reference I found about this tablet was the ads on eBay. I found sites that said android driver downloads but thought I'd get some feedback as to which android driver and what are good sites to check for info on tablets. I found this one, so if anyone can help, I'd appreciate it.
. I would greatly appreciate it if you could dump the stock rom from your tablet thanks!
