Installing CyanogenMod 7.2 on the Huawei Fusion 2!
Step 1:
Root your Fusion 2 using THIS GUIDE HERE.Step 2:
Install my build of CWM 6 for the Huawei Fusion 2 Using THIS GUIDE HERE.Step 3:
Backup your phones data using my backup guide HERE.Step 4:
Download CyanogenMod 7.2 from our link HERE!***DOWNLOAD LINK AT BOTTOM OF PAGE***Step 5:
Copy the downloaded .ZIP file to your Huawei Fusion 2's internal, or external SD Card.Step 6:
Power Off the phone. Step 7:
Boot into CWM by simultaneously holding the Power Button and the Volume UP KEEP HOLDING UNTIL IN CWM!! (NOT DOWN LIKE FASTBOOT) once in CWM select by using the volume keys to go up and down and the power button to make a choice. Choose Step 8:
WipeData/Factory Reset, then Wipe Cache, then advanced/wipe Dalvik Cache (DO EACH OF THESE 3 TIMES TO GET A CLEAN INSTALL)Step 9:
Next select INSTALL ZIP FROM SD CARD select the Cyanogenmod 7.2 zip once again using volume buttons to seek and power button to select. It will give you some kind of error, ignore this. Next go back and select reboot phone. The phone should boot as usual, but this time with CM7.2! Step 10 (OPTIONAL, ONLY USE IF YOUR PHONE STAYS AT CYANOGENMOD LOGO):
Your phone may go through one forced reboot. It's the only time that will happen. (IF YOUR PHONE STAYS AT THE CYANOGENMOD LOGO FOR 10 MINS+ PERFORM BATTERY PULL, WAIT 10 SECONDS MINIMUM, AND THEN BOOT INTO CWM. ONCE IN CWM DO THE WIPE DATA, WIPE CACHE, WIPE DALVIK (Three Times Total for Each) THEN SELECT REBOOT. YOU WILL NOW BE RUNNING CM7.2! )Step 11 (NOT OPTIONAL):
Enter in the correct APN settings. If using AT&T GO HEREthe link to the AT&T APN settings also has T-Mobile's APN settings!IF YOU DO NOT ENTER THE APN SETTINGS YOU WILL NOT GET A DATA CONNECTION. THAT MEANS NO INTERNET!! SO PUT THEM IN!PLEASE HIT LIKE, THANKS, THUMBS UP, OR DONATE IF YOU'RE FEELING SAUCY!
CM 7.2 V.1 BROUGHT TO YOU BY SHAGERTY, CAMERON581, AND ZEROSEDEV! (PLEASE THANK THE WHOLE TEAM IF YOU ARE HAPPY NOW.
:smokingsomb:
:smokingsomb:
Do you have the internal SD option and then side load? Or can you use the external too? My CWM6 doesn't have it, so might aswell ask. Because then you could have done a push of the zip via ADB.
