According to joey.. his kernel doesn't matter if you need patchoob or not joeykrim - SDX Kernel - Beta - Revision 4 - 2/24/2010 Since it is a complete recode of the way the kernel is...sry to beat a dead horse...im going to flash my newly purchased moment. It has CJ05. Which version of 12.1 should I download and also, where is the kernal for stock in case i need to go back to the stock version.
Post where joey talks about it is Login
Ya my bad.. that is in the developers boardThe post where joey talks about it comes up error.
I see ZE13.2 is out with some instructions I don't quite understand. Can we get a ZE13.2 install for dummies?
there are some detailed step by step directions posted regarding the CL14 "official" update process and how to use the sprint official tool to flash a custom kernel - http://www.sdx-developers.com/index.php?topic=731.0I see ZE13.2 is out with some instructions I don't quite understand. Can we get a ZE13.2 install for dummies?
Anyone had any luck on a MAC trying this. My windows computer is loaded cause I am waiting to put 7 on it and I cant get this to work on my macbook. I guess I just have to wait...
Hi Joey - thank you very much.there are some detailed step by step directions posted regarding the CL14 "official" update process and how to use the sprint official tool to flash a custom kernel - How-To: Using the Sprint Update Utility for Flashing
But I don't understand some of this. For instance:Hi Joey - thank you very much.But I don't understand some of this. For instance:
"1. Create a datatool back-up."
What does that mean? Thinking it might refer to the use of an app I searched market for "datatool" but nothing came up. So ... ?
Every answer raises more questions, of course!Datatool is a tool that is part of the custom recovery.
It saves your /data and /system and lets you restore it whenever you want.
Pretty neat.![]()
i have a question that has probably been answered several times. But i am completely new to the moment. I just got it a couple days ago and it came with the cl14 update to it. Can i still flash a kernel using the sprint utility or do i need to do something like the downgrade and then load. I'm a little confused, so i apologize if i missed the answer to this previously.
Yes - now you can!I have a question that has probably been answered several times. But I am completely new to the Moment. I just got it a couple days ago and it came with the CL14 update to it. Can I still flash a kernel using the Sprint utility or do I need to do something like the downgrade and then load. I'm a little confused, so I apologize if I missed the answer to this previously.
Just a heads up for anyone that is thinking about flashing to a new kernel, and decides to go with Zefie's 14.1, don't. All previous ones worked wonders, but for some reason no matter how many times I flashed with 14.1 I could not received SMS nor would VoiceMail notification, or Visual Voicemail work. Which for me, was kinda a big deal. Nothing against Zefie what so ever, 13 was awesome, but 14.1 has it's kinks to work out I guess.
