ragingbull2k2
Member
flashed with recovery 2.0... easier for me, and worked awesome...
Joey
Joey
thanksOkay here are the drivers Samsung Moment | Random Tech Info I have XP and the second set works for me
I think your issue is with New PC Studio being installed and resulting in driver conflicts
Just uninstall ANYTHING that says Samsung in it. Than reinstall Sprint Uploader(you should have it saved as a zip file or re D/L it should also install the drivers that you need
Hi all, this is my first real post/tech question here. I joined right after I got my Moment about a month ago. When I got it, it came with Android 1.6, and the CL14 update. About a week ago my phone decided to brick itself (not sure what happened, not even the Sprint Tech's could figure it out.) They replaced it (no-charge) with a brand new one. Thing is... this new one has 1.5, and cj05 on it, even thought they told me that this new one will have all the new updates, etc. already done.
My question is... where do I go from here? I either want to do the sprint update, or root it the best way possible so I can get the performance and speed back that I enjoyed when I got the first one. As it is now.. everything lags, dialing sucks, multiple sms causes the phone to lock, and multiple apps running sometimes causes the phone to restart. I want my sleek smooth droid back! lol
I am very tech minded, and have been reading up on rooting, and the different ways to do so. Which direction would you point a new guy like me, and why?
I have Samsung PC Studio 7 installed, and not running, as well as NOT having Firefox open.
yay... update to the update! i now have joey's 1.9.5, and max's recovery 2.0 on and running. Smooth and responsive.. and really fast bootup! i am happy! now... how to get rid of the crap i dont want on the phone... *waves bye to Moxier mail*
many thanks!
--You have now downloaded everything that you will need in order to proceed with installation--
14. Click Start – the process should only take a minute or two to run. If it gets stuck and doesn’t do anything, disconnect USB cable, pull battery on phone, and restart in Download Mode again. Reconnect USB cable. Try hitting Start in Odin again. It should take the second time.
Best of luck to you. Again, I – nor any other person – is responsible for your phone.
If I get enough requests, I may put together a similar guide for loading the Android SDK, specifically the ADB so you can adb shell into the phone to delete the stock apps.
