Help How to move APPs to Ext SD Card
Hi,
I am trying to move some of the applications to SD card. But funbook is allowing only to move to Internal SD card (2GB)
Can some one suggest how to move APPs to EXTSD?
There are some apps that are not moveable to extsd...
I know few are not moveable... But when I tried Angrybirds game, it is moving only to internal SD. No option of external SD.
I have also tried few applications like APP2SD. all those application treating IntSD as SD card. They are not recognising ExtSD.
I could move Angrybirds to ExtSD in my Galaxy Y (android 2.3). I did not observe any Internal SD in Galaxy Y. Is this Internal & External SD is new in Android 4.0?
Funbook has internal memory 2GB so u neednot move apps to external sd. Btw have u mounted any sdcard?
+1
if it has 2gb internel why is moving needed ;)
but still if needed,
sure you can use link2sd ( i think it must work fine with 4.0 -- i have never tried it ;) )
I have mounted 32GB MicroSD. It is showing as ExtSD under storage section. I want to move some of the games & non-critical applications to ExtSD to make internal memory free... so that the tablet can run faster.
Today I bought 16GB microSD card for micromax funbook. I also installed App2SD. But I am also facing the same problem as "madhubabuk". All apps get transferred from internal tablet storage to internal SD card instead of external SD card !!! :( Then whats the purpose of buying microSD card ???
Guys 2 gb is enough for apps ...just the problem u can face is for cache of hd games .
It wil only work from internal ....btw if u want yo dtore apss nd game cache in extsd then u can swap the sd from extsd ...procedure is posted here : Funbook
guys i too facing the problem with extsd card. In storage section extsd card is identified. But it is not shown in app-android assistance. Also unable to move apps to extsd using tools in app-android assistance. any suggestion please?
dowload script from funbook.gizmolord.com
works well, i tried
