How to optimize manage and stop Battery draining leakage? With setting or apps?
kumaranil13k
I have one of mobile Lyd water 7 LS-5504 Android 6.0 it has 3000mAh battery whenever I charge it charge quickly but if it's kept it switched on without using or even opening and kept aside screen display locked it's battery gets drained within approx 5hrs -6hrs means it's standby time is approx 5hrs-6hrs and using it's working regularly it's discharge time is approx 2hrs-4hrs the same company lyf water 8 has same 3000mAh battery it's standby time is approx. 48-72hrs means approx 2-3 days without using and if used it's working regularly discharge time is approx 10- 12 hours roughly.
Now I think it's some apps which using or draining is factory reset the mobile still without installing it's discharging just minute diff ie. Standby time approx 6- 7 hrs and usage time approx 3-5 hrs. May be some system apps using on disabling some of them still not much difference
I saw setting battery usage but it's not showing app wise usage.. then. Is saw process stats in developer option it show Google play services and Google play store chrome and all system apps running 97%
Now I want to know any app or setting to stop battery draining. Or optimizing battery usage .Found many apps like greenify or accubattery but it's need root access not paid versions. Is there any USSD codes or any setting to optimize or stop or maybe battery usage or test battery life or actual real battery mAh or correct settings.
Is there option of of service menu used code which self test calibrate or find error min mobile or battery or any 3rd party apps.tomtest battery or repair or calibrate or optimize it
dude.....you need to get a new phone
some phones have battery optimization that can help manage battery load and optimize it to last longer. i have this on my note 10+. you are dealing with very old tech.
rooting a phone and installing a custom kernel might help, but i doubt there are such things for your phone as their is no dev community to back your it.
