I'm not sure you need the full paths. I see them using chmod in init.rc which is in /system/bin, so I'm guessing "/system/bin" is not necessary. I'd try:
insmod /system/lib/modules/overclock.ko
setscaling.sh
I'm curious about something, what is the stock "scaling" setup?
The insmod would be necessary for both lines, correct?
insmod setscaling.sh
Okay then. I'm going for it in RE. If this bombs, I guess someone else can report using desktop while I recover.No. insmod tells it to load the kernel module overclock.ko. Just use it as I pasted it.
setscaling.sh
I don't want to redo my setup, but reboot and do:
cat /proc/overclock/mpu_opps
You'll notice the 1ghz slot is 66 vsel.
So an unrooted phone uses all the same values except for the 1 ghz slot that we're changing?
Well, I ran cat /proc/overclock/mpu_opps and got /proc/overclock/mpu_opps: No such file or directory. Did it not work?
So I added the lines but every time I reboot for some reason the two lines get erased. I am still trying though
Looks like we're going to have to find another startup script to modify
Edit:
I should have done my homework. init.rc is part of a ramdisk. So when you reboot, poof it is reloaded again. We'll need to find another init script that isn't part of a ramdisk. Back to the drawing board.
If you're using setclock.sh or overclock.sh, you're only changing the top slot. That is why I posted a setscaling.sh with modifications to all 4 slots.
I was looking through the init.rc and noticed it calls a couple other .sh scripts under /system. Why don't you try adding those 2 lines to:
/system/etc/install-recovery.sh
After fresh reboot:
$ su
# cd /proc/overclock
# cat mpu_opps
mpu_opps[4] rate=1150000000 opp_id=4 vsel=34
mpu_opps[3] rate=900000000 opp_id=3 vsel=30
mpu_opps[2] rate=600000000 opp_id=2 vsel=26
mpu_opps[1] rate=300000000 opp_id=1 vsel=22
After fresh reboot:
$ su
# cat mpu_opps
