How to push 5MP hack to darchdroid 2.7
download and place the Camera.apk in your android sdk tools folder
open up command (run, then type in cmd, black box should show up)
cd C:\android-sdk-windows\tools
adb remount
adb push Camera.apk /system/app/Camera.apk
Thank you for this, because not only have you helped me now, but this knowledge can be applied frequently in the future. :D
adb remount
Well done young grasshopper :). (I wonder where he learned to do that :p)
ok... im feeling pretty dumb right now. i have dl'd the apk... and i need to put it in the sdk tools folder... where in the world is that folder? is it sposed to be in on my sd card? cause i sure cant find it there.
you have to have android sdk in your comp first. then you put the camera.apk file into C:android-sdk-windows\tools\
