Root How to reinstall system apps _as_ system apps.
im using an x2 and i was uninstalling bloatware i uninstalled yahoo contacts and its ****ed up my contacts so i attempted to reinstall it with your method and variations of your method with various root explorers to no avail any suggestion?
I deleted a few system apps (all the social stuff, corp directory, email, etc). In a thread on DroidXForums (this one on the unrooting procedure) someone mentioned that they could not get the .604 update without some of the bloatware. Of course, this freaked me out a bit as I would certainly like to get Froyo when it comes out. So, I went about trying to reinstall the stuff I'd uninstalled. The system dump with all the default apps is here, and below is the procedure to get what you're missing reinstalled and visible as system apps. I used Root Manager but the same procedure should work for Root Explorer. If you prefer ADB I'm sure one of the more competent terminalists here can help you.
-Place the apk(s) of the apps on your sdcard.
-Use your chosen means to copy the apk(s) to /system/app (this will require making /system/app writable. In Root Manager just press the R/W key when you're exploring /system/app).
-You now need to change the app's permissions. In Root Manager, long press on the app (in /system/app) and click on "permissions". Then make sure that only the following boxes are clicked: User Read, User Write, Group Read, Others Read.
-Make sure you make /system/app read only again by clicking that box in the top right while you're exploring the folder.
-Reboot phone.
Now the apps should be loaded and the system should recognize them as system apps (you can verify by opening Titanium and noticing they're in red). This should make you good to go for whatever OTA comes. If you're unsure which apks in the system dump correspond to the apps you've deleted, just explore your /system/app and compare it to the system dump app list. Any apks in the dump but not in yours are what you're looking for.
i did this but after reboot the app doesnt open it says process com.google.android.app has stopped unexpectedly!! can u help me???
I've copied the .apks to my SD card, but when I try to copy them to the system/app folder (using Root Explorer with the folder mounted as r/w), it looks like it works, but the files are never copied. I've tried moving them instead of copying them as well. Any ideas?
