Root How to remove FlyX
aPSPer
Hello, I'm new to the Android world.
I received a Droid X(MB810) running FlyX v0.1 Final. I would like to put it back to it's original OS(?), or just as it was out of the box. It did not come with a SD card and I do not know if it was ever backed up.
This phone also is using ClockworkMod Recovery v2.5.0.6 to boot.
I know I'm totally missing something here, so be easy on me.
Thanks.
aPSPer, I moved your topic to the root forum where it will get better responses.
That being said I went and grabbed another link for you. This is a method where you will burn a bootable linux OS onto a cd and it will do it that way. IMO both are easy but the second one is my preference.
Just to add, since I didn't see it mentioned, if you decide to root again after returning to stock, you will need an SD card ;)
Thanks a lot folks. mruno, that worked perfect and I'm back to stock.
And yes, I will use an SD card in any future rooting adventures.
Thanks again!
