ttran97
Good guide, planning on removing Sense now that i found ADW much better, and more responsive. I'll probably wait on installing JIT for now.
Does anyone happen to know if there is a list of HTC Widgets that are safe to remove along with Sense? If no sense, no use in having stuff in just to waste space.
Unwanted Apps
Post number 26 by T2noob has a list of things that can be removed safely:
Here is a list of Apps and the Odex files me and Others have deleted without having any problems
And I don't remember the names you can figure it out yourself. They don't differ to much from app names.
If you do this make sure you make back ups, in case something goes wrong.
Nothing happened to mine doing this but some people on here are not good at following directions so do this AT YOUR OWN RISK!!!!
1) Visual voice Mail
2) Twitter both the app and the widget.
3) HtclockScreen.apk Deleting this will get you the nexus lock.
4) MMS (messages txt)
5) Stocks all 3 apks
6) Teeter
7) Browser
8) Amazonmp3
Things that could be deleted but I haven't tried or want to try because I use them.
9) Quickoffice
10) calendar apk and widget.
11) contacts The WIDGET NOT THE APP!!! I REPEAT DON'T REMOVE APP BUT ONLY THE WIDGET!!!!!
12) MAIL WIDGET Again not the app unless you want to go with out email or if you don't use it But I'm not even sure about this one.
And again do this AT YOUR OWN RISK!!!
Don't come complaining if something goes wrong Thats why you make Backups.
Taking out the first six frees up about 8.5 mb..You can use this for a long Bootanimation.
I've tested phone calls, text messages, some HTC apps (Dialer, Contacts, Mail, Messages), and I have the HTC clock/weather widget on my home screen. I haven't tested absolutely everything yet, but plenty is working that wasn't with the other JIT.
