Help How to rename external SD card?
fonduekid
Member
Hello People,
Can someone please tell me how to rename the external SD card? At the moment, it shows up as "external_sd".
Is there any way to change the name? Is it just a matter of renaming the folder? Or is it possible to give a name to the external SD card itself?
Thanks in advance.. Cheers.
Do you really want to rename the exernal SD card? I don't know whether this is doable and it might confuse the system and apps. I think keeping folders and apps with their default names in default locations is a good practice.
The previous discussion thread http://androidforums.com/samsung-galaxy-s2-international/331797-how-use-external-sd-card.html talks a lot about internal storage versus external storage.
Basically your apps and their data are stored in the internal storage /sdcard, and data like photos & videos can be stored in the external /external_sd unless you choose to change this behavior.
Hope this helps.
Shengxin
Thanks a lot.
Yes, I understand, that its the name of the file system mount point and I was wondering if there was a way to rename it.
For example, when I had a SD Card in my Nokia 5230, there I had the option to "name" my external memory card... and hence I was thinking if it was possible to do the same with the SGS2 / Android 4.0.
Anyway, thanks again for the clarification :-)
Shengxin is right. It's not a simple folder or volume name, it's the name of the file system mount point.
So if I want to change my SD Card's Volume name, which is "STRONTIUM" atm, can I do that with my phone itself without a PC? I am using a Xiaomi Redmi 2 Prime
Id like this info too~ SD card in mounts at sleep/boot constantly, renaming is one of the fixes I've been told
Need to do without PC
On tab running 5.o
