Root How to Restore ROM Backup
MrCritter
I've had my Droid X rooted for several months. I am currently running 2.2.1.
Over the weekend I played around with installing a custom ROM, Liberty 1.0. I love it, but some of my go-to features aren't working anymore (like long press on the search button to bring up voice search).
I would like to go back to my original, factory ROM. Can I simply go to "Factory reset data" under the Privacy menu of Settings?
If not, then I guess I would need to restore using a backup from clockworkmod, though I don't know how to do this. On my phone, I have the directory clockworkmod>backup>2011-01-20.02.11 with five files:
.android_secure.img
cache.img
data.img
nandroid.md5
system.img
Can someone tell me the easiest way to get back to my original, factory ROM?
Thanks!
Over the weekend I played around with installing a custom ROM, Liberty 1.0. I love it, but some of my go-to features aren't working anymore (like long press on the search button to bring up search).
.android_secure.img
cache.img
data.img
nandroid.md5
system.img
Thanks!
You can simply select the option to restore your rom from rom manager. It's that easy
